I don't want to bypass CNA!
  • 1.  I don't want to bypass CNA!
    Posted Oct 03, 2014 09:49 AM
    I've spent ages with customers before trying to bypass Apple's CNA but today I am with a customer who wants the CNA to pop up and I cant get it to happen!
    All captive portal is set up, bypass CNA is off in the CP Profile as well as in Clearpass. There are no additional allows in the firewall except to CPPM and also one to allow access to CPPM via an external link (this is required by the set up here due to the way the guest VLAN is protected from the internal network). There is no Apple whitelisting at all.
    Android and Windows devices all work correctly with their respective popups but CNA will not work.
    Using CPPM v6.0 (although patching to 6.1 as I write this) and AOS 6.4.2.1. iPhone is on OS 7.2
    Any ideas of where else I should look?
    Cheers
    Davey
  • 2.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 09:58 AM
  • 3.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 10:17 AM
    Tried it with and without landing.php. No joy.
  • 4.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 10:19 AM
    Just to point out CPPM version 6.4.1, not 6.1!
  • 5.  RE: I don't want to bypass CNA!
    Please publish your "logon" acl for your user:
    show rights <role>
  • 6.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 10:23 AM
    VH-Aruba-1) #show rights Customer-Guest-PreAuth
    Derived Role = 'Customer-Guest-PreAuth'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Periodic reauthentication: Disabled
     DPI Classification: Enabled
     Web Content Classification: Enabled
     ACL Number = 68/0
     Max Sessions = 65535
     Check CP Profile for Accounting = FALSE
     Captive Portal profile = CNGuest-CP-Profile
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                                Type     Location
    1         global-sacl                         session
    2         apprf-customer-Guest-PreAuth-sacl  session
    3         logon-control                       session
    4         AllowExternalCPPM                   session
    5         AllowCPPM                           session
    6         captiveportal                       session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
    apprf-Customer-Guest-PreAuth-sacl
    logon-control
    1         user    any                      udp 68                 deny                             Low                                                           4
    2         any     any                      svc-icmp               permit                           Low                                                           4
    3         any     any                      svc-dns                permit                           Low                                                           4
    4         any     any                      svc-dhcp               permit                           Low                                                           4
    5         any     any                      svc-natt               permit                           Low                                                           4
    6         any     169.254.0.0 255.255.0.0  any                    deny                             Low                                                           4
    7         any     240.0.0.0 240.0.0.0      any                    deny                             Low                                                           4
    AllowExternalCPPM
    1         user    83.244.191.151  svc-https               permit                           Low                                                           4
    2         user    83.244.191.151  svc-http                permit                           Low                                                           4
    AllowCPPM
    1         user    Clearpass    svc-http                permit                           Low                                                           4
    2         user    Clearpass    svc-https               permit                           Low                                                           4
    captiveportal
    1         user    controller   svc-https                     dst-nat 8081                           Low                                                           4
    2         user    any          svc-http                      dst-nat 8080                           Low                                                           4
    3         user    any          svc-https                     dst-nat 8081                           Low                                                           4
    4         user    any          svc-http-proxy1               dst-nat 8088                           Low                                                           4
    5         user    any          svc-http-proxy2               dst-nat 8088                           Low                                                           4
    6         user    any          svc-http-proxy3               dst-nat 8088                           Low                                                           4
    Expired Policies (due to time constraints) = 0
    Allow CPPM allows access to the clearpass VIP.
  • 7.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 10:31 AM
    It looks fine.  You might want to check the Apple forum so that you can get telemetry on if the CNA is triggered in IOS and why.  There is definitely a log on MAC OSX.
  • 8.  RE: I don't want to bypass CNA!
    Posted Oct 03, 2014 10:44 AM
    Goddam apple devices. Forgot the network and tried again and now it works.
    See here:
    https://discussions.apple.com/message/25443945#25443945
