I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
This thread has been viewed 55 times
  • 1.  I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted Sep 16, 2016 10:44 AM
    I have a 7200 controller. How can I force disconnect a client connected to one of the APs.The CLI "disconnect-user <IP address>" doesn't seem to work. Am I using the wrong command ?
    Bob
  • 2.  RE: I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted Sep 16, 2016 10:54 AM
    Client Supplicants will just reconnect a user that has been disconnected or deauthed.  It it is better that you blacklist a client and then un-blacklist a client if you want them truly disconnected.
    If you just want to log out a captive portal user, I would type "aaa user delete mac <mac address of user>"
  • 3.  RE: I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted Oct 16, 2018 07:53 AM
    Is there anyway I could do on web gui?
    Controller is running on AOS 8
  • 4.  RE: I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted Oct 16, 2018 10:57 AM
    Currently, this can only be done from the CLI in AOS 8.
  • 5.  RE: I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted May 23, 2019 09:40 AM
    Can this be done from the MM in AOS 8 or does it need to be done from mdconnect?
  • 6.  RE: I have a 7200 controller. How can I force disconnect a client connected to one of the APs.%0D%0A
    Posted May 23, 2019 09:52 AM
    not too sure about it as i have not tried it before.
    but only way now is thru the CLI.
