I have a 8.3 MM with 2 controllers attached, how do I delete AP's
  • 1.  I have a 8.3 MM with 2 controllers attached, how do I delete AP's
    Posted Jun 04, 2018 01:04 PM
    I have 8 AP's the incorrectly connected to my lab MM controllers,  they have been redirected to the correct place but now I see 8 down AP's on my MM.   How do I delete them?
  • 2.  RE: I have a 8.3 MM with 2 controllers attached, how do I delete AP's
  • 3.  RE: I have a 8.3 MM with 2 controllers attached, how do I delete AP's
    Posted Jun 04, 2018 04:44 PM
    Thanks Colin, that did it.
  • 4.  RE: I have a 8.3 MM with 2 controllers attached, how do I delete AP's
    Posted Apr 13, 2021 12:49 PM
    I have a smiliar issue where I cant remove an entry which is no longer seen on the MM controller but still being seen on the MD controller
    Every command I try to run from the MD controller says 'This command must be run on the master.'
    Any adivse will be greatly appreciated
    David
    David Hurley
