I have an Aruba 7210 with AP-275's and AP-225's.
  • 1.  I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 10:21 AM
    I have an Aruba 7210 WLAN controller with AP225's and 275's.  I have set up each AP with a static IP.  I can ping from the console connection to each AP with a good reply.  My issue is I can't get the APs to connect to the controller.
    Controller IP:     10.79.11.5              Gateway:  10.79.11.1                   Subnet:  255.255.255.0
    AP IP range:  10.79.11.10- 10.79.11.49
    Control Plane is diabled
    This is a system that is stand alone on my desk for testing purposes.  I can't find any info to set up 7210 with static ip addresses assigned to the APs.
    #7210
    #AP225
  • 2.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 10:42 AM
    Did you set the controller-ip address for the acces points during provisioning so that it can find the controller?
    #7210
  • 3.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 10:57 AM
    While in console and watching the AP boot it runs ADP and finds the master as 10.79.11.5 which is the 7210
    #7210
  • 4.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 10:58 AM
    Type "show ap database" and see what the controller thinks about those access points.
    Also, type "show log syste 50" to see if there are any messages about those access points.
    #7210
  • 5.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:06 AM
    Where would I type that command in?  Console of the AP or the 7210?
    #7210
  • 6.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:09 AM
    How did you provision those access points?  If you use the console, it would be "setenv master <ip address of master>".  If you used the GUI, it would be the master ip address.  But you say that the access points are finding the master, according to the console...
    #7210
  • 7.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:12 AM
    I consoled into each one and used these commands.
    setenv ipaddr 10.79.11.x
    setenv netmask 255.255.255.0
    setenv gatewayip 10.79.11.1
    save
    boot
    I watched the AP boot up and start ADP and all of them found the master as 10.79.11.5.
    #7210
  • 8.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:16 AM
    You need to type "setenv master <ip address of master>" if you are not using DHCP.
    Well, you need to type "show datapath session table <ip address of acess point>"  on the controller to see if it is sending the controller any traffic.  That is the first step.
    Next, you need to type "show log system 50" to see if there are any problems with that access point, if it is already sending traffic.
    #7210
  • 9.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:28 AM
    Here is the response I get from that command on the console of the 7210
    (DEWLAN) User: admin Password: ********
    (DEWLAN) >show datapath session table 10.79.11.48
    ^ % Invalid input detected at '^' marker.
    (DEWLAN) >show datapath session table10.79.11.48
    #7210
  • 10.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:29 AM
    You need to be in enable mode to run that command.
    #7210
  • 11.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:43 AM
    He is the snip of what it told me
    #7210
  • 12.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:46 AM
    AP 275s require ArubaOs 6.4 and above..http://www.arubanetworks.com/products/access-points/270-series/
    It looks like the AP is requesting a binary that does not exist on the controller that suggests you are not running 6.4 and above.
    #7210
  • 13.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:50 AM
    The controller came with 6.2.0.0
    #7210
  • 14.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 12:08 PM
    As long as you purchased or have a valid support contract go to support.arubanetworks.com and download the latest 6.4.x (I believe it's currently 6.4.0.3) and flash the controller with that. This will allow both APs to function. The 225 requires a minimum 6.3.x and the 275 requires 6.4.x.
    #7210
  • 15.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 01:02 PM
    Thanks all.  I will complete and let you know if there are any issues
    #7210
  • 16.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 01:24 PM
    FYI:  you cannot upgrade from 6.2.0.0 directly to 6.3
    #7210
  • 17.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 11:54 AM
    Yes, and you need to upgrade it with 6.4 or above or The 225s and 275s will not work.
    #7210
  • 18.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 03:19 PM
    I have the upgrade completed and the access points can now be provisioned.  FYI I used TFTP to transfer because the 7200 series will not let you upgrade from local file option
    #7210
  • 19.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted May 08, 2014 07:46 PM
    did you use eval license? check in controller license page if they are active. I sometimes find that eval license became inactive, after i change my controller's clock.
    #7210
  • 20.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Aug 13, 2014 03:06 AM
    Did the AP275 and AP225 show up as active?
    #AP225
    #7210
  • 21.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Aug 25, 2014 08:51 AM
    Hello again,
    #7210
  • 22.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Aug 25, 2014 09:19 AM
    Hello again.
             We have installed our AP 225's and AP 275's.  The WLAN has been up for a while but we have yet to get more than 1 AP 275 working.  The symptoms we are having are that the 275"s boot up and find the master but they don't broadcast no matter how many times we provision them.  I have consoled into the AP and watched it boot and it gets to the "Welcomne to the AP275" and "watchdog process finished nanny will restart."  Then Nothing.  Some 275's show blinking Green light and some show solid red.  Only 1 is letting clients connect and it has no light.  These are very confusing sysmptoms and I am having a hard time nailing down the culprit.  I am going to be very discriptive, see below
    We have a 1gigabit uplink to a Cisco 2960 in a parking deck with 6 AP275's patched to it.  I also have an AP 275 coming from the MDF.  We ended up buying 30W POE injectors so we can rule out POE power from the switch being an issue.  The only AP275 that clients can connect to is in the parking deck.  It is plugged int o port 1 on the cisco switch.  All of the ports on the 2960 have been duplicated to match the 1 port that AP275's work on.  Any AP275 I put  on port 1 of the 2960 works.  Why don't the others?  The AP275 in the MDF is off of a Cisco 3750X.  There are 35 APs connected to a stack of 9 3750X's without any issue.  275's from MDF don't broadcast either.
    i have attached what console shows.
    #7210
    Attachment(s)
    txt
    Ap275#1.txt   8 KB 1 version
    txt
    ap275#2.txt   6 KB 1 version
  • 23.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Aug 25, 2014 10:05 PM
    Think you captured the "insuffiecient POE Voltage" issue :)
    Now to solve it...
    Cheers,
    Michael
    #7210
  • 24.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Feb 19, 2015 06:53 PM
    You need to enable LLDP on the switches.
    #7210
  • 25.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Feb 21, 2015 05:25 PM
    sorry i have not read all the comment
    have you ugrade your controller to 6.4 as suggested before,  are you always recieving the message "Shutting down eth1 due to insufficient POE voltage",
    is the security plan disable or not.
    #7210
  • 26.  RE: I have an Aruba 7210 with AP-275's and AP-225's.
    Posted Aug 15, 2015 09:18 AM
    I don't know if the issue was found in your case but I'm currently deploying AP-275 in a big manufacture to replace old Cisco Autonomus AP-1231. Our switch stack all around is standardized with Cisco 3750X 48ports. I just realized that on some stack the AP-275 once provisionned will appear as Inactive and in some other stack they will show as Active without the I flag. It's running on M3 with AOS 6.4.2.9. I started to dig into this issue during this week and yesterday I found that there is common denominator to those with the I flag. There are connected on stack running Cisco IOS 15.0(1)SE2 . The other AP-275 that work fine are on stack running Cisco IOS 15.0(2)SE2. All the stack have LLDP enabled. So it must be a bug with Cisco IOS version.
    Anyway I will continue to dig into this next week. If someone have other information related please share!
    #7210
