I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
  • 1.  I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 11, 2014 01:30 PM
    Dears I have a big issue I have controller 3600 and AP85 and AP68 and bought a Ap103 now AP 103 support only OS 6.4 but AP85 doesn't so in this situation what should I Do?
    #3600
  • 2.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 11, 2014 01:41 PM
    Either split the old APs onto a separate controller or replace the APs
  • 3.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 11, 2014 05:02 PM
    is replaceing for free ?
  • 4.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 11, 2014 05:15 PM
    No, but there are discounts available when moving to 11ac access points.
  • 5.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 11, 2014 06:17 PM
    thank you somuch dear TC :)
  • 6.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 12, 2014 05:35 AM
    Dear Tim kindly assisst ,if I got another controller and make it local and Upgrade it to 6.4.1 and terminate AP-103 on it and the Master will remain 6.3 so AP85 can work it will work fine or no? and also if I nee to move license from controller to another how many days needed for that?
  • 7.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 12, 2014 07:45 AM
    You cannot have a master and local running different versions of code. The only thing you can do if you must run both APs is to stand up two separate controllers, one with 6.3 and the other with 6.4. You can put the same configuration on them, etc, manage them under AirWave, etc.
  • 8.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 12, 2014 08:43 AM
    Dears ok nw I have the license for the new APs inslatlled on the controller so I will need to know in centeralized license the 2 controller must be the same OS code? and what time required to move license from one controller to another?
  • 9.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 12, 2014 09:03 AM
    Centralized licensing should work between a 6.3 controller and 6.4. The license table is updated every 30 seconds.
  • 10.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Aug 12, 2014 11:53 AM
    thanks guys for support
  • 11.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Jan 13, 2015 04:01 AM
    Hello Tim,
    we have quite a similar situation at the moment, but only with AP-68 and AP-103.
    Is AP-68 supported under ArubaOS 6.4.x.x?
    Since i read in the Release Notes for i.e. 6.4.2.1 that it contains bugfixes regarding AP-68 and ArubaOS 6.3, i assume they are supported. Can you verify this?
    AP-85 is not present in our network.
    Kind regards,
    Jan
  • 12.  RE: I have AP85 and AP68 and the new AP 103 I upgraded to 6.4.1 b AP85 is down?
    Posted Jan 13, 2015 07:04 AM
    please check this:
    http://www.arubanetworks.com/support-services/end-of-life-products/
    so yes the AP68 is supported in 6.4.x.
