i have aruba controler 650 and am forget password login my network on wifi and am need to change or
  • 1.  i have aruba controler 650 and am forget password login my network on wifi and am need to change or
    Posted Dec 27, 2014 05:35 PM
    i have aruba controler 650 and am forget password login my network on wifi and am need to change or reset it please
  • 2.  RE: i have aruba controler 650 and am forget password login my network on wifi and am need to change or
    Posted Dec 27, 2014 11:54 PM
    Are you trying to reset the controller login password or your network key?
  • 3.  RE: i have aruba controler 650 and am forget password login my network on wifi and am need to change or
    Posted Dec 28, 2014 11:48 AM
    - Here is process for resetting the login password. Please use the Password Recovery process:
    Please login using console with a serial cable (e.g. you must be infront of the controller):
    Login : password
    Password: forgetme!
    Then go into enable mode with pwd “enable”
    Config terminal
    #Mgmt-user admin root
    <hit enter to setup the new root password>
    Once done logout and login back in with the new password.
    Do not forget to execute #write memory in order to save the new password.
    - If you are looking to decrypt the wireless security key which you have setup for your wireless network. Please execute #encrypt disable and then execute #show run, under the config you will see the wireless key in clear text under your VAP profile section.
