I have Self Register Captive Portal on Clearpass guest now when guest connect to guest ssid and wait around 2 to 3 minutues without entering credentials he disconnected automatically ..is there is a reason for this?
What type of client device is connecting to the captive portal? Are you also seeing the client device drop from the user table on the controller?
-Mike
Android devices, that have this issue actually
Within the Android family, is it devices that are older than Android 4? I've had a lot of success with Android 4.3, 4.4, and the new 5.0.
Thanks!
thanks for replay I tested this issue on 4.2 and 4.3 and it happen on both
What settings would do so.. can you please Specify ?
