i installed clearpass PM and after changing the gui admin password m unable to login using that pass
  • 1.  i installed clearpass PM and after changing the gui admin password m unable to login using that pass
    Posted Apr 28, 2014 04:22 PM
    Hello
    after installing CPPM and canging te admi password for gui access, im unable to login using that password. I can't login using the default one either
    Is there any way toreset this via cli?
  • 2.  RE: i installed clearpass PM and after changing the gui admin password m unable to login using that pass
    Posted Apr 28, 2014 04:26 PM
    From page 26 of the CPPM user manual:
    Resetting the Passwords to Factory Default
    To reset Administrator passwords in Policy Manager to factory defaults, you can login to the CLI as the apprecovery
    user. The password to log in as the apprecovery user is dynamically generated.
    Perform the following steps to generate the recovery password:
    1. Connect to the Policy Manager appliance via the front serial port (using any terminal program). See "Resetting the
    Passwords to Factory Default" on page 26 for details.
    2. Reboot the system. See the restart command.
    3. After the system restarts, the following prompt is displayed for ten seconds:
    Generate support keys? [y/n]:
    Enter ‘y’ at the prompt. The system prompts you with the following choices:
    Please select a support key generation option.
    1) Generate password recovery key
    2) Generate a support key
    3) Generate password recovery and support keys
    Enter the option or press any key to quit:
    4. To generate the recovery key, select option 1.
    5. To generate a support key and a recovery key and support, select option 3.
    6. After the password recovery key is generated, email the key to Aruba technical support. A unique password will be
    generated from the recovery key and emailed back to you.
    7. Enter the following at the command prompt:
    [apprecovery] app reset-passwd
    * WARNING: This command will reset the system account *
    * passwords to factory default values *
    Are you sure you want to continue? [y/n]: y
    INFO - Password changed on local node
    INFO - System account passwords have been reset to
  • 3.  RE: i installed clearpass PM and after changing the gui admin password m unable to login using that pass
    Posted Apr 28, 2014 04:33 PM
    is this different on a vm?
    *looks like its the same*
    So i need to contact support either way
    Thank you. I'll just call
  • 4.  RE: i installed clearpass PM and after changing the gui admin password m unable to login using that pass
    Posted Apr 28, 2014 04:37 PM
    I believe for a VM you need to contact TAC.
