I want the best configuration for using Avaya Wireless IP-Phones as I can't find it and thanks
I have attached a document , its a little bit old doc but should get you through ...I used it for an Aruba wireless deployment using Avaya phones and those worked with no issues with these settings.
Attachment(s)
Thansk Victor I can see taht I should use SVP in acl session but what about the TOS value should I change it to 46 as I migh have no access to the avaya manger and is there is any changes in the new OS and avaya new OS?
You should match it with the same value that is being use across your infrastructrure
