Plz I need to ready many documents to implement clearpass from the scratch so what is documentations should I read and kindly provide what shoud I read first ?
You should really work with your Aruba team or a partner or take a training class. ClearPass can be difficult to deploy without any experience.
thats why I asked fro some documents that I shoudl read before the Deployment and I will check with partner but if you can provide me with any helpfull documenst will be great
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=14768
Realy Thank you you are one of the best :)
Also be sure to check out Aruba Solutions Exchange. It can help you build out configurations.
https://ase.arubanetworks.com/
Hi Tim
Can you plz give me an example of configuration workflow like what to configure first ?
