I need to upgrade Mobility controller from Aruba OS 8.2.1.1 to 8.6.0.4 . Can i directly upgrade the code or need to follow the recommended path from Aruba.
  • 1.  I need to upgrade Mobility controller from Aruba OS 8.2.1.1 to 8.6.0.4 . Can i directly upgrade the code or need to follow the recommended path from Aruba.
    Posted Mar 19, 2021 09:38 AM
    can anyone please suggest on this. I will be very thankful.
    Madhuraj Kushwah
  • 2.  RE: I need to upgrade Mobility controller from Aruba OS 8.2.1.1 to 8.6.0.4 . Can i directly upgrade the code or need to follow the recommended path from Aruba.
    Posted Mar 19, 2021 10:08 AM
    you can upgrade it directly. no need to worry
    [hao] [yang]
