I pad and I Phones are getting slow browsing in Aruba wireless Network
  • 1.  I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:07 AM
    Dear All
    We are experiencing slow browsing on I Pad and I phones with aruba wirless. all the windows amchines are workign fine.
    Any body has any idea about it. How to resolve this issue.
  • 2.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:31 AM
    Please describe your setup:
    When did this start happening?
    What type of APs do you have
    Are you using encryption?
    How many access points?
    What model controller?
  • 3.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:39 AM
    Please find below the answers in red.
    its start at the time of deployment.
    AP105
    No encryption is using.
    46
    3400
  • 4.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:40 AM
    How many wireless clients do you have on your network?
    Are the wireless clients in the same subnet as wired clients?
  • 5.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:42 AM
    Around 200 users are using the wirless network  and wireless clients subnet is different with wired client.
  • 6.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 08:43 AM
    Do you have "drop broadcast and multi cast" enabled on that virtual ap?
  • 7.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 09:01 AM
    i need to check the option then will let you know.
    thanks your prompt reply.
  • 8.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 09:05 AM
    hw to enable "drop broadcast and multi cast" in virtual AP. Is this a check option or we need to creat a profile and apply it.
  • 9.  RE: I pad and I Phones are getting slow browsing in Aruba wireless Network
    Posted May 13, 2012 09:25 AM
    Go to configuration> Wireless> AP Configuraton.  Edit the ap-group that your access points are in.
    Expand Wireless Vlan> Expand Virtual AP.  Click on the Virtual AP that corresponds to your wireless network.  In the right pane you should see "Drop Broadcast and Multicast".  You also need to enable "Convert Broadcast ARP requests to unicast", as well.
    Click Apply in the lower right hand corner.
    See if that makes a difference.
    If it does, for best performance, you should enable this on all your Virtual APs in that AP group.
