I recently unbox a iap205, use wizard for new ssid and nothing happened, hide ssid.
  • 1.  I recently unbox a iap205, use wizard for new ssid and nothing happened, hide ssid.
    Posted Nov 02, 2014 01:23 AM
    I don´t know how i can see the SSID. I select Mexico country, i see the first signal "instant", but after select the country and process the wizard for create a new wlan, and i not see the signal on my ipad, mac and cellular.
  • 2.  RE: I recently unbox a iap205, use wizard for new ssid and nothing happened, hide ssid.
    Posted Nov 03, 2014 01:43 PM
    I had exactly the same problem. Found out that the country code I was using had not had the new AP approved. Try another country code and see if it works.
  • 3.  RE: I recently unbox a iap205, use wizard for new ssid and nothing happened, hide ssid.
    Posted Nov 07, 2014 12:36 PM
    if you are using a 205, you should have a base firmware of 4.1.1.0, which has support for Mexico.
    Can you post your configuration?
    You can always try a different country code as well.
  • 4.  RE: I recently unbox a iap205, use wizard for new ssid and nothing happened, hide ssid.
    Posted Nov 07, 2014 02:03 PM
    I use CANADA, and we see a SSID and vuala!!
