I'm trying to upgrade and I got error
Uploaded file is invalid: does not have the meta file or unrecognized type or does not have a valid signature.
Image i (CPPM-x86_64-6.5.0.71095-upgrade.signed) and it is HW-5K with OS 6.3.1
Sure but it is stucking and say downlao dintrupted while internet speed is very high and I tested with same IP on PC and internet speed is very well but dont know why it keep doing this?
I also downloaded 6.3 cumulative patch 6 and importing it and gives error Upload is not compatible: update is already installed or is a lower version than one on the system
Usually use teh CLI method :
To do update (Patch)
#system update -i http://<subscription_id>:<subscription_id>@Clearpass.arubanetworks.com/cppm/patches/<Patch File name.bin>
you can see all in:
To Upgrade
#system upgrade -i http://<subscription_id>:<subscription_id>@Clearpass.arubanetworks.com/cppm/firmware/<firmware File name.bin>
and for sure to be able to see all enter the subscription number in both authentication fieds.
Hi
Does this CLI method needs Cleapass to be connected to the internet?
BEcause I am getting error on upload from GUI from 6.2.6 to .6.5
I am downloading directly from HPE my support.
When I import the file it gives that error "upload file is invalid"
Also read all release notes and for file 6.3.0 the error is the same.
Regards
What browser are you using? Some browsers re-name the file extension and this causes issues. Don't forget to check the MD5 sum as well.
