We are using AP-103 and 6.4.1.0 code release.
Google play store and internet is working we have trouble accessing apple store alone has anybody faced the same issue before ?
You may need to add a netdestination (itunes store) in the role you are using.
Actually here is another recent post about the same problem. Might keep an eye on it as well.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Issue-with-IOS-clients-on-APs-on-VPN-unable-to-access-Apple/td-p/207527
We dont have a PEF license ..
I tunes store uses standard http 80 and 443 ports dont think this should be an issue.
Do we need to enable itunes services on the AIrgroup profile ?
No, you should not need PEF or AIrGroup.
While you're attempting to connect, can you run the following command from the controller
show datapath session table | include 17.154
We are using bridge mode on the SSID so i dont think show datapath session table will be visible for the users.
Can you confirm that a wired user in the same subnet can access the services?
We were using a cisco access point ealrier it was working fine and we have replaced it with AP-103 and it stopped working.
