Wired Intelligent Edge
i want to configure extended acls in aruba 2540 switch
  • 1.  i want to configure extended acls in aruba 2540 switch
    Posted Oct 03, 2018 01:57 AM
    and only access for only admin system in SSH only
    how to write extended acls in this switches kindely help me guys.
    #ACLs
  • 2.  RE: i want to configure extended acls in aruba 2540 switch
    Posted Oct 09, 2018 08:23 AM
    Hello Ganil,
    An extended ACL can permit or deny traffic based on both the source and destination address(s) as well as tcp/udp/icmp trafic types.
     For an extended ACL ID, use either a unique number in the range of 100-199 or a unique name string of up to 64 alphanumeric characters
     Example ,
    Aruba-Switch(Config)#ip access-list extended “Abcd” (Creates an extended access list Abcd)
     Aruba-Switch(config-ext-nacl)#10 deny tcp 0.0.0.0 255.255.255.255 192.168.1.2 0.0.0.0 eq 25 (Denies everyone access to port 25 on 192.168.1.2)
     Aruba-Switch(config-ext-nacl)#20 permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 (Permit any to any for any IP service)
    Aruba-Switch(vlan10)#ip access-group “Abcd” in (Applies the access list 100 in an inbound direction for vlan 10)
     Aruba-Switch(Config)#show access-list (Displays configured access-lists)
  • 3.  RE: i want to configure extended acls in aruba 2540 switch
    Posted Oct 10, 2018 01:10 AM
    ok i will try
    thank you.
