I want to configure mesh on IAP105. help me please
  • 1.  I want to configure mesh on IAP105. help me please
    Posted Nov 22, 2011 04:11 AM
    help me
    i have the IAP105   2 units
    i want to configure mesh portal and mesh point
    How do i configure
  • 2.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 22, 2011 05:03 AM
    If you update to the lastest firmware on both, Mesh should be enabled automatically.
  • 3.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 22, 2011 05:30 AM
    yes i upgrade firmware laster version 6.1.2.3-2.0.0.1_31127
  • 4.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 22, 2011 05:37 AM
    Mesh should work by default.  What are you trying to do?
  • 5.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 23, 2011 11:47 AM
    Hi Wanasans, I have the same setup, 2 IAP-105, same firmware and followed the User Guide to the letter, first connected the APs to a DHCP server, they showed up having the mesh portal role, after this we disconnected one of the APs and connected again, it never shows in the VC again as it should (as a Mesh Point).
    If you were able to make it work please post it here, thanks
  • 6.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 23, 2011 02:43 PM
    Are you saying that you disconnected it from the wired network and then connected it to the wired network again, OR did you just provide power so that it could see the other access point?
  • 7.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 23, 2011 08:57 PM
    Just provided power, they should have showed up but did not
  • 8.  RE: I want to configure mesh on IAP105. help me please
    Posted Nov 28, 2011 02:42 PM
    Today I upgraded the two IAP-105 to 6.1.2.3-2.0.0.2_31127, and I can´t make them work with mesh, I started all over after upgrading firmware, connected the IAPs, made a new WLAN, diconnected one of them (power and network) and reconnected power, this mesh point should be seen in the VC under Access Point, nothing happens, I´ve cheched if there´s any configuration regarding mesh in the VC GUI but I don´t find any, please if anyone has made this setup work maybe can point us to where the problem is, thanks in advance
  • 9.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 01, 2011 08:54 AM
    it works ok for me, can you attcach the result (goto 'support' tab and run command 'AP Tech Support Dump')?
  • 10.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 01, 2011 12:56 PM
    Hi hlv,
    Attached are the outputs first with both APs connected to the switch and after one of the APs was disconnected (data only)
  • 11.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 01, 2011 03:12 PM
    Now they work, it seems the problem was a Country code, in my case is CL, I changed for testing purposes to CA and everything is fine now.
    I have opened a case with TAC so they pass this information to developers
  • 12.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 02, 2011 08:28 AM
    may i know the country code of the mesh portal (CA or CL)?
  • 13.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 02, 2011 10:42 AM
    The Country code that did not work was CL, for testing we changed it to CA and it did work
  • 14.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 03, 2011 08:01 AM
     I setup 2 AP105 with wired and configure a BSS on the VC, after this two APs reboot,  disconnect one Ethernet link only power supply, it can works as mesh point.
  • 15.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 03, 2011 09:06 AM
     I'm use Country code PH, It works too, seems a bug related with CL country code
  • 16.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 05, 2011 09:33 PM
    Instant only support mesh work on 5G Hz band, 5G channle not allowed under Chile rules.
  • 17.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 07, 2011 11:30 AM
    Where did you get this info about 5 ghz? I'm afraid this is not correct and if Aruba is not permitting 5 ghz. For country code CL they've made a mistake.
  • 18.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 09, 2011 10:14 PM
    Band3 , 100 to 140 are not allowed
    Band 1, Band2,Band4 allowed but no present approval for this Aruba product
    I got this info till 2011/8/6
  • 19.  RE: I want to configure mesh on IAP105. help me please
    Posted Dec 09, 2011 10:37 PM
    Band 1 36/40/44/48/
    Band 2 52/56/60/64
    Band 4 149/153/157/161/165
  • 20.  RE: I want to configure mesh on IAP105. help me please
    Posted Jul 24, 2012 08:45 AM
    Hello.
    Maybe this will help somebody :)
    Next steps works for me (from factory reset):
    1) connect all (two) AP's to LAN, give them IP from DHCP
    2) connect to VC
    3) configure country - CZ works fine for me; SK works too
    4) disconnect ethernet cable from 'MESH point AP'
    5) unplug 'MESH point AP' from power (reboot it) and wait to boot
    After this steps one AP act as Mesh Portal and second as Mesh Point.
    Now you can do some other configuration as ESSID etc.
    REMEMBER !!!!
    If there is Mesh Portal and Mesh Point working, 5GHz radios will not propagate your ESSID.
    Jaroslav
