I was installing an AIP115 but after configured everything I found that Radios never show power/chan
  • 1.  I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 10:40 PM
    I was installing an AIP115 but after configured everything I found that Radios never show power o channel or any data for any band
  • 2.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 11:32 PM
    What version is running on your IAP-115?  Is this a -US or "Rest of World" model?  If ROW what country code are you setting?  Can you also tell us the color each of the LEDs?  Are there other IAPs running?
  • 3.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 11:34 PM
    I, I try changing it to CA and it works, I have it in SV.
    How can I see if it is a ROW?
    Leds were amber!
  • 4.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 11:38 PM
    On the back of the IAP you will find a model sticker.  If it says "IAP-115-US" it is a US model or "IAP-115-RW" is Rest of World.  Also, only the Rest of World version will ask you for a country code.
    Depending on the version of SW on the IAP you may be trying to set a CC that is not supported by that release.  Let us know what version.
  • 5.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 11:41 PM
    Ahh ok. I'm connected remote, but it asked Country Code so I can asume it is ROW.
    This is the Version version 6.3.1.0-4.0.0
    I tryied to upgraded from maintenance window, but the "Check for new version" timed out!
  • 6.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 11, 2014 11:48 PM
    Not sure what version you are running as you are missing the last digit.  Log in and use the CLI command " show version" or in the GUI go under "Maintenance".
    You can also log into the TAC site (requires a support contract) and download the latest release (6.4.2.0-4.1.1.1).
  • 7.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 12, 2014 05:31 AM
    Which country code did you configure on the AP? And do you know the software version running on the AP?
  • 8.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 13, 2014 12:42 AM
    Hi, Where can I set country code for IAP 205? I am using Aruba Central.
    Thank you.
  • 9.  RE: I was installing an AIP115 but after configured everything I found that Radios never show power/chan
    Posted Nov 19, 2014 08:08 AM
    I set it using this command: virtual-controller-country CO
    by CLI.
    SV is not currently supported on this AP.
