IAP-0205: Restore Configuration all Accesspoints at once (cli)
  • 1.  IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Jun 14, 2017 06:24 AM
    Hello.
    One small qusition: how can I restore a configuration from a tftp server via ssh and force the controller to push this configuration to all accesspoints?
    I do (on controller)
    # tftp [tftp-server-ip] [filename] system config
    and get
    please reboot the AP to apply the new configuration
    All fine after "# reload" if there is only one accesspoint.
    Not, if there are more than one.
    What happens then is:
    If I reload the contoller accesspoint is, that the controller accesspoint reboots and after that gets the old config from one of the other accesspoint which is now the new controller.
    In this way I will never be able to restore the configuration of all present accesspoints.
    So my question ist:
    How can I force the controller to push the uploaded configuration to all accesspoints and force all accesspoints to reboot?
    (This is what happens if the restore is done on the web interface)
    Best regards,
    All-X
  • 2.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Jun 14, 2017 06:46 AM
    Do you have an instant cluster?  You should reboot them all at once.
  • 3.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Jun 14, 2017 06:50 AM
    Yes, i do.
    Is there a way to do this reboot of all access-points via cli on the controller?
    Best regards.
  • 4.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
  • 5.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Oct 19, 2017 02:17 AM
    I`m sorry, but that didn`t fix the problem.
    Sometimes it seems to work, but in other times it does not.
    Here is exactely what I type:
    ap-01# copy tftp 192.168.1.55 configtoberestored.cfg system config
    ap-01# commit apply
    committing configuration...
    configuration committed.
    ap-01# reload all
    Do you really want to reset the system (y/n): y
    y
    Now the accesspoints reboot as expected.
    After the reboot I sometimes get the configuration I wanted to restore, sometimes the former configuration and somtimes a "mixed" configuration which contains three valdid SSIDs an two SSIDs named "instant".
    Thy for replay.
    Best regards
  • 6.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Oct 20, 2017 01:54 AM
    Hmm....
    Anyone?
  • 7.  RE: IAP-0205: Restore Configuration all Accesspoints at once (cli)
    Posted Oct 20, 2017 06:55 AM
    Are you doing all of this work from the Virtual Controller?
    You should type "show aps" to make sure that it can see all of the APs in the cluster.  If it cannot see all APs, you are only restoring your configuration to some of the APS.
