IAP-103 at home
  • 1.  IAP-103 at home
    Posted Feb 03, 2016 10:36 PM
    Airheads - I have an IAP-103 at home, and it works great, except in the corner of the house.  I purchased what I thought was another IAP-103 on ebay, but I think it may actually be an AP-103.   Can my existing IAP control the AP?   What options do I have?
    My apologies if this question is in the wrong place
    Thanks!
  • 2.  RE: IAP-103 at home
    Posted Feb 03, 2016 10:40 PM
    You can either purchase a controller, try to return the AP-103 or try to sell it on eBay.
    Sent from Nine
  • 3.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:19 AM
    developer testing comments0
    #AirheadsMobile
  • 4.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:25 AM
    comment testing0
    #AirheadsMobile
  • 5.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:27 AM
    test #AirheadsMobile
  • 6.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:29 AM
    testtt
    #AirheadsMobile
  • 7.  RE: IAP-103 at home
    Aruba Sensor, a small, dual-band 802.11n client radio and a Bluetooth Low Energy (BLE) radio, makes it easy for IT to turn a mobile engagement proof-of-concept into a full-out, multi-location deployment by pulling beacon data into one centralized location.
    The Aruba Sensor plugs directly into an AC outlet and can hear other Aruba Beacons within a 25-meter range and reports relevant data over Wi-Fi to the cloud-based platform
    #AirheadsMobile
  • 8.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:34 AM
    eee
    #AirheadsMobile
  • 9.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:42 AM
    test
    #AirheadsMobile
  • 10.  RE: IAP-103 at home
    Posted Feb 04, 2016 02:56 AM
    anupam testing #AirheadsMobile
  • 11.  RE: IAP-103 at home
    Posted Feb 04, 2016 03:06 AM
    Aruba Sensor, a small, dual-band 802.11n client radio and a Bluetooth Low Energy (BLE) radio, makes it easy for IT to turn a mobile engagement proof-of-concept into a full-out, multi-location deployment by pulling beacon data into one centralized location. The Aruba Sensor plugs directly into an AC outlet and can hear other Aruba Beacons within a 25-meter range and reports relevant data over Wi-Fi to the cloud-based platform #AirheadsMobile
