IAP 103 broadcasting low (54) mbps rates.
  • 1.  IAP 103 broadcasting low (54) mbps rates.
    Posted Dec 22, 2014 07:37 AM
    Hi people,
    Im created 3 IAP103 AccessPoints to use for Site Surveys.
    What happend is that I created a normal SSID with both 2,4ghz and 5 ghz enabled, I disabled the option that will disable the SSID when there is no link on the port, that all works.
    Now, when I check the SSID's it sends out (through Ekahau with an NIC300 WLAN adapter), now what I see is this:
    In the Image above you see there are the configured 40mhz 5ghz channel and the 2,4ghz 11n channel. But where do the 54Mbps ssids come from?
  • 2.  RE: IAP 103 broadcasting low (54) mbps rates.
    Posted Dec 22, 2014 08:19 AM
    Patrick s,
    Why not connect to it and see what rate your client gets...
  • 3.  RE: IAP 103 broadcasting low (54) mbps rates.
    Posted Dec 22, 2014 08:23 AM
    Its not about what the clients are connected with, these AccessPoints are only for Survey means.
    Normaly it never shows those low rates. I just after I gave it a factory reset it started broadcasting those SSID's. I just want to know what caused this or how to disable them.
  • 4.  RE: IAP 103 broadcasting low (54) mbps rates.
    Posted Dec 22, 2014 08:25 AM
    Patrick s,
    Without connecting a client to the survey SSID or using another application to view the rates that are displayed, we cannot really explain why Eckahau is reporting those rates.
    EDIT:
    Please use INSSIDER, packet capture tool or another program to see if still reports it as 54 so that we can determine if there is a bug in the AP103 or if there is an issue with Eckahau.
