IAP 103 can't join on 3200 Controller
  • 1.  IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 09:11 AM
    Hi there,
    i have IAP 103 can not join on 3200 Controller, the IAP and Controller in the same VLAN
    IAP get IP from DHCP but can't find the Controller, tried to activate the DHCP server on the Conrtoller itself , IAP got the IP normally but still can't join
    i checking it by AP installation under Wireless tap
    Controller Version 6.3.1.5
    IAP version 6.4.0.2-4.1.0.0_44004
    Note.
    - I added an entry in DHCP server for Conntroller IP mapping to aruba-master. but still the IAP can't join
    - added the IP of the Conntorller on the IAP manually but with no success also
    - IAP Auto join mode : enable
    - Conntroller discovery mode:enable
     map Controller IP
  • 2.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 09:18 AM
    Minimum ArubaOS version for the 103 is 6.4.
    http://www.arubanetworks.com/products/access-points/103-series/
  • 3.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 09:41 AM
    Did you convert the IAP to a controller-based AP.?
    Tim
  • 4.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 09:43 AM
    thanks for your reply,
    coudl you please help me from where i can download version 6.4 for 3200 Controller ?
  • 5.  RE: IAP 103 can't join on 3200 Controller
  • 6.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 09:52 AM
    Yes. You need to upgrade your controller to 6.4 (from support.arubanetworks.com) and then convert the IAP to a controller AP from the maintenance tab.
    Tim
  • 7.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 10:04 AM
    thanks Tim
    but i just read that frol 6.4 release not
    ArubaOS 6.4 is supported only on the newer MIPS controllers (7200 Series, M3, 3200XM, 3400, 3600, and 600
    Series). Legacy PPC controllers (200, 800, 2400, SC1/SC2) and 3200 controllers are not supported. Do not
    upgrade to ArubaOS 6.4 if your deployment contains a mix of MIPS and PPC controllers in a master-local setup
    do you think i can upgrade ?
  • 8.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 10:06 AM
    Sorry misread. Thought you had a 3200XM. You'll either need to buy a memory upgrade kit or a new controller.
    Tim
  • 9.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 10:08 AM
    If you're already running 6.3 you most likely already have the memory upgrade as you need that to get past 6.1 I believe.
  • 10.  RE: IAP 103 can't join on 3200 Controller
    Posted Jan 27, 2015 10:23 AM
    may you are right.
    ruba Operating System Software.
    ArubaOS (MODEL: Aruba3200), Version 6.3.1.5
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-04-08 at 20:23:43 PDT (build 43118) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.1.0 (build 35189)
    Built: 2012-09-06 16:05:33
    Built by: p4build@re_client_35189
    Switch uptime is 5 hours 44 minutes 29 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:50)
    Supervisor Card
    Processor XLR 508 (revision C4) with 1187M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB)
  • 11.  RE: IAP 103 can't join on 3200 Controller
    Posted Feb 10, 2015 04:51 PM
    the AP joined after upgraded the controller to 6.4, thanks all for your help
