IAP 103 DRAM & Flash Memory ????
  • 1.  IAP 103 DRAM & Flash Memory ????
    Posted Apr 14, 2014 10:26 AM
    hi
    i have a tender and it required that the IAP must have DRAM 256 MB & Flash 32 MB and i elect IAP 103 SO
    does IAP 103 Fit these requirements ?
    if no which IAP can meet these requirements ?
    where i can found these info ? becouse its a tender and the client need a prove
    thanks ,
    best regards ,
    #AP103
  • 2.  RE: IAP 103 DRAM & Flash Memory ????
    Posted Apr 27, 2017 09:02 PM
    IAP-103 has 128MB SDRAM and 32MB FLASH
