IAP 103 not instant wifi and led off 5ghz 2.4ghz
  • 1.  IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 25, 2016 03:45 PM
    Hi , I have aruba iap 103 , when i swith on, I have not instant wifi and led off 5ghz 2.4ghz , even when I reseted the device as i saw the forum , no way , again i have already AP installed and managed via controller , I can not see AP on the controlleur.
  • 2.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 25, 2016 10:13 PM
    Is it an IAP-103 or an AP-103?
  • 3.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 03:59 AM
    thanks for your reply ,
    i have IAP 103
    REGARDS
  • 4.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 04:19 AM
    When you reset it, try to find out the ip address and SSH into it using "admin" and "admin".  When you login type "show log system" and post the log here.
  • 5.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 04:28 AM
    Please note that I have already 4 AP installed and managed by controller.
    I already check system log, o, the controller where i cannot find any record regarding my new IAP , No @ MAC.
    whatr about led off 5ghz 2.4ghz ? can I configured with the led off 5ghz 2.4ghz ?
    Even Power  LED  is stable juste when I switch on after that it's start flashing,
  • 6.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 04:43 AM
    You are having problems just starting the IAP-103?
    If you have an IAP, you need to convert it before adding it to a controller.  Are you having a problem just starting the IAP or after trying to convert it?  I am trying to figure out which one you are having problems with..
  • 7.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 06:13 AM
    Honestely , I didn't try to convert it, and i don't know how i can do it!!!
    for me I'm thinking that the probem comming from led off 5ghz 2.4ghz.
    means Problems to starting IAP .
  • 8.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 06:15 AM
    i don't know how i can convert , if i cannot acces to IAP because i have not instant Wifi , and IAP cannot joint my controller
  • 9.  RE: IAP 103 not instant wifi and led off 5ghz 2.4ghz
    Posted Nov 26, 2016 06:29 AM
    If you are not seeing the Instant SSID, you should find out the ip address that the instant AP gets, SSH into it using "admin", "admin" and type "show log system" to see what could be keeping it from broadcasting "instant"..
