IAP-103 radio 5GHz is down
  • 1.  IAP-103 radio 5GHz is down
    Posted May 10, 2016 04:41 AM
    I've a strange issue with two IAP-103, namely leds PWR ENET 5GHz are on and green, 2.4GHz is off, but SSID is visable only on 2.4
    04:bd:88:c8:74:c7# show ap bss-table
    Aruba AP BSS Table
    bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t
    04:bd:88:07:4c:70 test ?/? 192.168.99.12 g-HT ap 11/19/19 0 04:bd:88:c8:74:c7 0 1m:41s
    On console I noticed this error:
    sapd config ERR or radar found: setting wifi0 wrong channel 11 or country 578, vap mode 8
    wifi0: Channel 11 cc=242 not found
    What can be a problem?
  • 2.  RE: IAP-103 radio 5GHz is down
    Posted May 10, 2016 06:00 AM
    What version of IAP software is this?
    What country code are you using?
  • 3.  RE: IAP-103 radio 5GHz is down
    Posted May 10, 2016 06:15 AM
    6.4.4.4-4.2.3.1 but the same problem with previous software version which I used 6.4.3.1-4.2.0.1
    NO (NORWAY) but, I changed it, in order to see if makes the difference.
  • 4.  RE: IAP-103 radio 5GHz is down
    Posted May 10, 2016 06:51 AM
    I would contact TAC.  You could have a hardware issue.
  • 5.  RE: IAP-103 radio 5GHz is down
    Posted May 10, 2016 07:52 AM
    You might be right, I checked 3 IAPs, and 3rd was okay.
    Thx.
