IAP 103 RADIO Inactif
  • 1.  IAP 103 RADIO Inactif
    Posted Nov 25, 2014 08:35 AM
    Dear All,
    i upgrade my IAP 103 into InstantOS 6.4.2.0-4.1 . the problem is that the RADIO are inactive. what can be the probleme
    Best Regards.
  • 2.  RE: IAP 103 RADIO Inactif
    Posted Nov 25, 2014 08:48 AM
    What is the regulatory domain?
  • 3.  RE: IAP 103 RADIO Inactif
    Posted Nov 25, 2014 10:09 AM
    My regularity domain is DZ (algeria) , and i think that the probleme is with that , i will see with my custumer.
  • 4.  RE: IAP 103 RADIO Inactif
    Posted Jan 22, 2015 05:05 AM
    I have the same problem. When I access a new IAP205 and choose Algeria in the Coutry Code Window, the radio goes down and can't access the device until default config reset. Did you find a solution ?
  • 5.  RE: IAP 103 RADIO Inactif
    Posted Jan 22, 2015 05:39 AM
    Yes ,now the solution is simply to reset you IAP  from console or from the reset button , and next  you reconfigure you IAP using another Regularitory domain.
