IAP 103 Radio issues.
  • 1.  IAP 103 Radio issues.
    Posted Mar 11, 2015 10:10 AM
     I have a problem with my IAP 103, when i disconnect the ethernet cable, the Radio go down.
    I try to convert in AP Standalone, but no solve.
    Is possible make sure the radio stay up when i disconnect the ethernet?
    Tipo:     103
    ora build: 2014-11-05 10:44:10 PST
    Versione: 6.4.2.0-4.1.1.1_46936
    Stefano
  • 2.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 10:13 AM
    In the IAP under the network you want to stay up choose edit. On the first page select Show Advanced Options
    THere should be an option "Disable SSID on uplink failure:" Turn this off.
  • 3.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 10:46 AM
    Thanks ELiasz,
     Where i can find the option "Disable SSID on uplink failure:"?
  • 4.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 10:49 AM
    In the Instant GUI select your network which you want to stay up. Click edit. Under the WLAN Settings on the bottom there should be an option "Show Advanced options". It should in in the right column near the bottom. This option needs to be enabled per SSID.
  • 5.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 10:58 AM
    Hi ELiasz
    Thank you very much, now works
    Stefano
  • 6.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 12:21 PM
    Are you trying to use the IAP for a survey?  This thread explains how to setup for that.
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/m-p/57274/highlight/true#M549
  • 7.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 12:28 PM
    Hi Michael,
    I needed just to the survey
    thanks for the guide
    Stefano
  • 8.  RE: IAP 103 Radio issues.
    Posted Mar 11, 2015 10:33 AM
    Hi Stefano,
    Here I'm not clear what exactly you are expecting. the expected behaviour of an IAP is, the radio will be up as long as the UP link is up but if it is a Mesh point radio will be up even if it is disconnected from the ethernet. if you are expecting a Mesh point you need to meet the following,
    1. IAP should have joined the cluster and updated it's image and configuration
    2. Extended SSID should be disabled ( in the latest code, extended SSID is enabled by default)
    Hope you got some more clarity, lease feel free for any further help on this.
