IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
This thread has been viewed 16 times
  • 1.  IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 04, 2017 06:00 PM
    I have a few IAP-103 access points that were recently upgraded and are no longer allowing me to login to the GUI. If I connect a console cable to them they boot successfully and then start displaying "turn off mobility" over and over. These are IAP-103s with the model # APIN0103. Can anyone help please.
    Here is the output from the CLI:
    APBoot 1.5.3.21 (build 47715)
    Built: 2014-12-17 at 19:19:51
    Model: AP-103
    CPU: AR9344 revision: 1.2
    Clock: 560 MHz, DDR rate: 429 MHz, Bus clock: 214 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 32 MB
    Power: 802.3af POE
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0033 00002 01 10000004 00000000 00000000 00000000
    Net: eth0
    Radio: ar9590#0, ar9344#1
    Hit <Enter> to stop autoboot: 0
    Booting OS partition 0
    Checking image @ 0xbf100000 (bank 1)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x81c00000 (8611832 bytes)
    Loading .data @ 0x82436800 (32 bytes)
    Clearing .bss @ 0x82436820 (16 bytes)
    ## Starting application at 0x81c00000 ...
    Uncompressing...................................................................................
    Aruba Networks
    ArubaOS Version 6.4.2.6-4.1.3.2 (build 56106 / label #56106)
    Built by p4build@chios on 2016-08-15 at 03:33:19 PDT (gcc version 4.3.3)
    CPU Rev: 2122
    934x CPU
    flash_size passed from bootloader = 32
    arg 1: mem=128M
    Flash variant: 32M
    ath_sys_frequency: cpu apb ddr apb cpu 560 ddr 429 ahb 214
    Cache parity protection disabled
    ath_timer_init: plat time init done
    Using 280.000 MHz high precision timer. cycles_per_jiffy=560000
    Memory: 118016k/131072k available (1698k kernel code, 12960k reserved, 673k data, 7712k init, 0k highmem)
    available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=34441728
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ..............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
    PCI init:ath_pcibios_init
    Returning IRQ 64
    ATH GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Concatenating MTD devices:
    (0): "bank1"
    (1): "bank2"
    into device "flash"
    Creating 1 MTD partitions on "flash":
    0x00000000-0x02000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    Domain Name: instant.arubanetworks.com
    No panic info available
    Backup ENV.
    ATHR_GMAC: RX TASKLET - Pkts per Intr:16
    ATHR_GMAC: Mac address for unit 0:80b0abc0
    ATHR_GMAC: 94:b4:0f:cf:6c:8e
    ATHR_GMAC: Mac capability flags : 42201
    ATHR_GMAC: Mac address for unit 1:80b0abc0
    ATHR_GMAC: 94:b4:0f:cf:6c:8f
    mac:1 Registering S27....
    ATHR_GMAC: Mac capability flags : 42A00
    athrs17_reg_init:done
    Phy setup Complete
    Cfg len is 0
    Configuration file is empty, turning on default services...
    extended ssid activate due to no AP config ...
    disable auto topology rules
    Starting up in standalone mode
    drvlog_mod: module license 'Proprietary' taints kernel.
    AP xml model 76, num_radios 2 (jiffies 15240)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    election init: rand=a HZ=500
    IAP client match init
    notify asap_mod 3g no present...
    notify asap standalone ap...
    Starting watchdog process...
    Got all network params from APboot env. Skippingathrs17_reg_init:done
    DHCP
    Setting PHY...
    Phy setup Complete
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    10.35.21.25 255.255.255.0 10.35.21.1
    Compressing all files in the /etc/httpd directory...
    Enet:0 port0 up
    athr_gmac_poll_link: unit 0 link change to up
    ATH_MAC_TIMER: enet unit:0 is up...
    Mii 1000Mbps full duplex
    ATH_MAC_TIMER: Done cfg2 0x7235 ifctl 0x0 miictrl
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    ip_time_handler: Got ip and packets on bond0 Started master election 1-0, rand 24
    drvlog_mod: module license 'Proprietary' taints kernel.Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    Restoring Cal data from Flash
    Reading from Addr: 0xbffe5000
    ath_attach: scn 85fc0280 sc 85ea0000 ah 85f80000
    wifi0: Base BSSID 94:b4:0f:76:c8:f0, 16 available BSSID(s)
    bond0 address=94:b4:0f:cf:6c:8e
    br0 address=94:b4:0f:cf:6c:8e
    wifi0: AP type AP-103, radio 0, max_bssids 16
    wifi0: Atheros 9580: mem=0x10000000, irq=64 hw_base=0xb0000000
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    ath_ahb: init_ath_wmac
    Enterprise mode: 0x00000000
    Reading from Addr: 0xbffe1000
    ath_attach: scn 87f80280 sc 87fa0000 ah 87fc0000
    wifi1: Base BSSID 94:b4:0f:76:c8:e0, 16 available BSSID(s)
    wifi1: AP type AP-103, radio 1, max_bssids 16
    wifi1: Atheros 9340: mem=0xb8100000, irq=2
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
    <<<<< Welcome to the Access Point >>>>>
    User: process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    i am master now
    (00:01:10) !!! Init ---> Master
    asap_send_elected_master: sent successfully
    turn off mobility
    turn off mobility
    turn off mobility
    turn off mobility
    turn off mobility
  • 2.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 04, 2017 06:53 PM
    Please let us know the steps that led to this.  We can only guess with the limited information presented.
  • 3.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 04, 2017 08:13 PM
    Thanks for the quick reply. I was having some issues with the APs being stuck in a boot loop so I hooked it up to a serial cable. When I did, it said that there was no Bootable image on partition 0. I then directed it to my tftp server with an updated image and ran the bootap>upgrade os 0 command to upload the new image to partition 0. When it finished successfully, I did a factory reset and rebooted. It now loads to the instant os, but I'm having the issue as described above. If there is any other useful information I can provide please let me know.
    #AirheadsMobile
  • 4.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 11:28 AM
    Did you try the reset switch?  Not sure why you would have a bootloop in the first place.
  • 5.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 11:31 AM
    Yes, that was my first line of troubleshooting, but when I held down the reset switch to factory default the units they were still trying to boot as if they were looking for a controller instead of booting to the Instant OS.
  • 6.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 11:37 AM
    It seems like you have a controller-based AP.  It cannot be converted to an IAP....
  • 7.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 11:50 AM
    I have 8 of these units all with identical model numbers of APIN0103. Three of them are functioning perfectly as they should, as Instant Access Points in a cluster but the others are stuck in this boot loop. They were sold to me as Instant APs and if you look up that model number, Aruba designates that they are in fact Instant APs. I appreciate the input, I just don't understand how some of them would work just fine and some of them wouldn't if they aren't supposed to be Instant.
    This might be of use:
    I just fired up one of the units that I have not modified in any way that is stuck in the boot loop and this is the result:
  • 8.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 12:02 PM
    That is a Campus AP.  You should let whoever you purchased that from know that and try to get them to exhange it.  Campus APs cannot be converted to IAPs in the field.  Their personality is set in the manufacturing process, unfortunately.
  • 9.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 12:17 PM
    So the Model #s are exactly the same for APs and IAPs? I know that didn't use to be the case with the 105s(we currently have AP-105s and IAP-105s). Seems like that would get very confusing.
    Also, since this is supposedly a Campus AP, shouldn't it be registering with our Campus Controller? Something here just doesn't add up...
    Do you know why I am getting the error SAPD: Reboot after image upgrade failed: 65280 ?
  • 10.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 05, 2017 03:21 PM
    APIN0103 is the regulatory number, not the model number.
    A campus AP should register with your controller if a discovery method is configured correctly, the controller is configured to accept foreign APs and the controller has code for that AP model.
    I don't know why you are getting that error.
    You should (1) attempt to return the APs and/or (2) contact TAC so that you can get this sorted out.
  • 11.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 11:50 AM
    Chris,
    You should always check the product part number (SKU) that is on the white sticker (right in the image below). The black label is the same for AP, IAP, and all country variants and shows the model as it has gone through FCC (and others) testing. This is true for all AP's and IAP's: just check the part number on the attached white sticker:
    As explained before, you cannot run Instant firmware on an AP-103 access point, you will need an IAP-103 version. If you try to flash Instant Firmware from the apboot, you will see the 'turning off mobility' messages and the AP will not come online, which has been mandated by FCC (and other) regulations.
  • 12.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 12:30 PM
    Any idea what this part number would indicate?
  • 13.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 01:38 PM
    Did you do a google search for that part number?  It is not familiar to me.
  • 14.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 01:40 PM
    Even better:  You can ask the organization that you got it from, what it means...
  • 15.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 01:51 PM
    Unfortunately, I got them from eBay as-is (I know, not a good idea, but we were in a pinch) Of course now I'm in an even bigger pinch because I can't get half of them to work :(
    I did a google search but didn't come up with much. Just one result of an inventory list of some kind. Didn't help much.
  • 16.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 02:09 PM
    The inventory list had a part number that has OAW-AP103 (Alcatel), which is NOT an IAP, but a Campus AP...
  • 17.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 02:55 PM
    Well, it's not the answer I was hoping for, but it looks like I just have to face the music.
    Will I be able to flash these back to the non-instant standard image?
  • 18.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 03:10 PM
    Reset button?
  • 19.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 03:45 PM
    I think I may have upgraded both partitions on one of the APs. Is that one shot?
  • 20.  RE: IAP-103 upgraded, wont allow GUI login repeats "turn off mobility" at console
    Posted Jan 06, 2017 04:33 PM
    You can try flashing it with an IAP Image from here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=21997
    No guarantees it will work, though.
