IAP 104 and IAP 175 support for number of IAPs on single IAP
  • 1.  IAP 104 and IAP 175 support for number of IAPs on single IAP
    Posted Sep 03, 2012 10:58 PM
    I researching product Aruba IAP 104 and 175. I want to know "” single IAP 104/175 can control to 64 IAPs or not ?”.
    If not, how many these product support IAP ?
    Thank
  • 2.  RE: IAP 104 and IAP 175 support for number of IAPs on single IAP
    Posted Sep 04, 2012 01:36 AM
    Yes you can have 64x IAP104/IAP175 in one virtual controller.
  • 3.  RE: IAP 104 and IAP 175 support for number of IAPs on single IAP
    Posted Sep 04, 2012 02:33 AM
    Thank ariyap
    and IAP 92, 93, 105, 134, 135 support ???
    Can you send for me that document ?
    Help me !
  • 4.  RE: IAP 104 and IAP 175 support for number of IAPs on single IAP
    Posted Sep 04, 2012 02:51 AM
    As long as you do not have IAP92/93 in the mix, you can go up to 64 IAPs.
    but as soon as you introduce IAP92/93 in the mix, then you can only go up to 16 IAPs.
  • 5.  RE: IAP 104 and IAP 175 support for number of IAPs on single IAP
    Posted Sep 04, 2012 02:58 AM
    Mean:
    I understand " IAP 92, IAP 93 support up to 16 IAP" & IAP 105, IAP 134, IAP 135 can up to 64 IAP" ??
    Do i understand is correct ??
    Can you send for me document ( document writted this problem)  ?
    [Personal Information Removed]
    Thank ariyap so much
