last person joined: 5 hours ago
IAP-104 instant wlan not up on default configuration?
  • 1.  IAP-104 instant wlan not up on default configuration?
    Posted May 28, 2014 01:02 AM
    Bought a couple of IAP's for a remote site that is in need of a mesh link. However when booted up the AP's, pwr is green and channel lights are red/amber.
    I have connected antennas, but it seems like there is no default configuration for the instant network (used for configuring).
    I have made a purgeenv -> saveenv -> reset. But still the same result.
    Had a similar problem with some IAP-92 the other day where the instant network was broadcasting but there the web server did not respond. A purgeenv did help then. But now I am stuck.
  • 2.  RE: IAP-104 instant wlan not up on default configuration?
    Posted May 28, 2014 08:40 AM
    As a first step - have you provided the IAPs with a DHCP address and are they all connected on the same subnet?
  • 3.  RE: IAP-104 instant wlan not up on default configuration?
    Posted May 29, 2014 11:22 AM
    use factory_reset to reset to factory defaults.
    As MattF pointed out, are they connected to a DHCP server? They won't broadcast 'instant' unless the IAP receives a DHCP IP.
    If it is still not working, assign an IP address to it by stopping the boot sequence and attempt to load the WebUI by IP to configure the IAP.
  • 4.  RE: IAP-104 instant wlan not up on default configuration?
    Posted May 29, 2014 01:48 PM
    I have seen this behavior when the IAP doesn't have an IP address
    Please confirm that the IAP has an IP address .
    From console try to ping the gateway
