IAP 105
  • 1.  IAP 105
    Posted Apr 03, 2013 03:22 PM
    I have a IAP 105 on my home network.  It is connected to a Netgear GS108T, that is connected to a Netgear WNDR3700.  Every since I updated the firmware on the 105 I cannot get beyond the router.   I can not ping beyond my router by IP or  DNS.  As soon as I unplug the 105 I can get outside my LAN.  The Aruba IP is 192.168.1.15, the IP of my router is 192.168.1.1.  When this problem appears if I try and browes to https://192.168.1.1 I am getting the Aruba login (instant.aruba.com).   What is causing this?
  • 2.  RE: IAP 105
    Posted Apr 03, 2013 03:45 PM
    Check your InstantAP configuration,it's seems your ap aint configure right,or you getting the wrong user role.
    u may do some screenshots,or copy your configuration (from the maintence window),and i will be able to assist u better.
    Me
  • 3.  RE: IAP 105
    Posted Apr 03, 2013 03:50 PM
    Here is a copy of my config.  At work we are running AP 104, 105.  I have never setup an IAP before and I am not sure it is setup correctly either.  Also when I look at the WebUI is says Master 192.168.1.2, the only IP I have assigned is 192.168.1.15 so I am not sure where the 1.2 is coming from
    version 6.2.0.0-3.2.0
    virtual-controller-country US
    virtual-controller-key 49ef52b00187bc9b662fc726f2d1ff6d979533ee57e3dee689
    name FBI_VAN
    virtual-controller-ip 192.168.1.15
    clock timezone Pacific-Time -08 00
    rf-band all
    allow-new-aps
    allowed-ap d8:c7:c8:cd:b8:d1
    arm
    wide-bands 5ghz
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    opendns freebird317 d7942df6784a4a7f8bd18e85cc3b1441537fc0043bb1d453
    device-id 00102FA2C7E69C3F
    vpn primary 192.168.1.15
    vpn preemption
    mgmt-user admin 5f189a5e704b0978df22a06ac7bfbb89cfa469caa6985f97
    wlan access-rule default_wired_port_profile
    rule any any match any any any permit
    wlan access-rule Home
    wlan ssid-profile Home
    index 0
    type employee
    essid Home
    wpa-passphrase 5f74f90f4b5b48c72d516ebd8ab7aa671dc12e8d25085a3a
    opmode wpa2-psk-aes
    max-authentication-failures 0
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    enet-vlan guest
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids classification
    ids
    wireless-containment none
    ip dhcp Home
    server-type Local
    server-vlan 1
    subnet 192.168.1.0
    subnet-mask 255.255.255.0
    lease-time 27600
    dns-server 192.168.1.1
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    id _airplay._tcp
    id _raop._tcp
    airgroupservice airprint
    disable
    description AirPrint
    id _ipp._tcp
    id _pdl-datastream._tcp
    id _printer._tcp
    id _scanner._tcp
    id _universal._sub._ipp._tcp
    id _printer._sub._http._tcp
    id _http._tcp
    id _http-alt._tcp
    id _ipp-tls._tcp
    id _fax-ipp._tcp
    id _riousbprint._tcp
    id _cups._sub._ipp._tcp
    id _cups._sub._fax-ipp._tcp
    id _ica-networking._tcp
    id _ptp._tcp
    id _canon-bjnp1._tcp
  • 4.  RE: IAP 105
    Posted Apr 03, 2013 04:01 PM
    Your eth port in your iAP is configure to work in front of a trunk port:
    at your home..if u using normal home equitment - ...your port is an access port.
  • 5.  RE: IAP 105
    Posted Apr 03, 2013 04:05 PM
    Sorry for noob questions.  But what does that mean?  Do I need to change the switchport-mode?
  • 6.  RE: IAP 105
    Posted Apr 03, 2013 04:07 PM
    Yep,
    Change it to Access.
    And than check if u have pings to your home router.
  • 7.  RE: IAP 105
    Posted Apr 09, 2013 07:47 PM
    why are you configure the VPN to point it to the virtual controller IP?
