IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
  • 1.  IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
    Posted Feb 06, 2014 03:00 PM
    I am trying to figure out how to set up an IAP 105 to work with both Captive Portal and MAC Auth.  I already have a guest SSID setup that is doing Captive Portal but there is now a need to have a few of our hosts bypass the Captive Portal and sign on with MAC Auth.  Is this possible with IAP 105s and AirWave?
  • 2.  RE: IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
    Posted Feb 06, 2014 04:48 PM
    Yes, this should be possible.
    What are you using for the authentication server? Internal or external RADIUS server?
  • 3.  RE: IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
    Posted Feb 06, 2014 05:18 PM
    I was thinking of using our ClearPass server.  Looking into how to setup on boarding with the end device.
  • 4.  RE: IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
    Posted Feb 06, 2014 07:43 PM
    A couple of things like setup of CA, the onboarding pages etc. Check with your local SE if need to.
  • 5.  RE: IAP 105 and AirWave - 1 SSID with Captive Portal and MAC Auth
    Posted Feb 07, 2014 03:36 AM
    If you just want to add MAC authentication you don't need onboarding. For MAC authentication you can use the endpoint repository as your authentication source.
