IAP-105 and AP-175
  • 1.  IAP-105 and AP-175
    Posted Jun 22, 2012 12:30 PM
    Hello, recently set up 4 IAP-105's indoors, one of them is the master controller. We are attempting to now setup an AP-175 outdoor unit. Unfortunately the controller cannot "see" the AP-175. Can the AP-175 work in conjunction with the IAP-105 controller? Thinking maybe we were supposed to get the IAP-175 instead of the AP-175.
    My boss is in the field attempting the install, and he has reassured me that the LAN cable they are plugging the AP-175 into is on the same subnet...
  • 2.  RE: IAP-105 and AP-175
    Posted Jun 22, 2012 12:36 PM
    The IAPs can not communicate with a non-IAP access point. The master will not be able to 'see' the AP 175 unless it is running the same IAP software.
    Are you trying to create a mesh link between two buildings or is the plan to have an outdoor IAP?
    thx, Shashi
  • 3.  RE: IAP-105 and AP-175
    Posted Jun 22, 2012 12:41 PM
    Thanks Shashi, the objective is to have an signal outside, but conrollable by the IAP-105 inside master.
  • 4.  RE: IAP-105 and AP-175
    Posted Jun 22, 2012 12:46 PM
    You'll need an IAP-175 for this to work
