Hi Guys,
I have an issue where if the aruba access points are on a Tagged port they do not see each other and autoconfigure, but if I change the port to untagged, they auto configure and see each other, the issue then is the client does not get a DHCP address on the SSID associted with that VLAN.
Any ideas? Switch is Netgear Pro Safe M4100-50G-POE (GSM7252P)
Rob.
