iAP 105 cant broadcast all SSID in iAP225 after 105(client) joint iAP225(master).
  • 1.  iAP 105 cant broadcast all SSID in iAP225 after 105(client) joint iAP225(master).
    Posted Sep 22, 2014 04:27 AM
    I joint my current iAP 105 to my new iAP 225 master as client after i upgraded my iAP105 firmware. It working and iAP105 able to joint iAP225. But, i found that the iAP105 cant received all the SSID created in master iAP225.For example, i had created 4 SSID inside my 225 virtual controler but the iAP105 can only broadcast 2 of the SSID out of 4. Does anyone encounter the same problem as me before? Thanks
    #AP225
