IAP-105, captive portal, and HTTPS
  • 1.  IAP-105, captive portal, and HTTPS
    Posted Oct 23, 2012 11:44 AM
    To my amazement, it seems that you can't enable HTTP over HTTPS for captive portal.
    I called and according to the tech, I can't upload a cert even if I go out and purchase one.
    Why would Aruba do this? Why force uncertified HTTPS? We're going to get non-stop requests on, "Why is this page red? Should I proceed?"
    Is this all true, is there an easy workaround? Are there any plans about changing this? Maybe even a beta firmware?
    If not, if someone could just give me a good reason why Aruba would do this. What is the logic behind this? Is there a place were customers can make requests for future features?
    I'm regretting buying so many of these and deploying them to our remote offices.
    Thanks in advance.
  • 2.  RE: IAP-105, captive portal, and HTTPS
    Posted Oct 23, 2012 11:49 AM
    What version of code are you running on the IAP?
  • 3.  RE: IAP-105, captive portal, and HTTPS
    Posted Oct 23, 2012 11:51 AM
    I should have added that.... I think I'm running the latest version: ArubaInstant_Orion_6.1.3.4-3.1.0.0_35320
  • 4.  RE: IAP-105, captive portal, and HTTPS
    Posted Oct 23, 2012 11:55 AM
    Go to Maintenance and select the "Certificates" tab. You will see an option of "Upload New Certificate".
  • 5.  RE: IAP-105, captive portal, and HTTPS
    Posted Oct 23, 2012 12:02 PM
    Thanks for the response, hthakker.
    The tech support person told me that's only for a proxy server? Maybe he was mistaken or misunderstood?
    Also, for me to create a new cert, don't I need to have a private key? How would I go by obtaining that?
    EDIT: I meant, don't I need a CSR?
