iAP 105 Captive Portal inquiry
  • 1.  iAP 105 Captive Portal inquiry
    Posted May 12, 2015 03:18 AM
    Hi Airhead,
    I have an iAP 105, usually when "Internal Acknowlege" is chosen, there would be 3 boxes. The "welcome box", "policy box" and the "email/name" of guest user. But in my case, I only see  welcome box and policy box. I hope you could help me enabling the 3rd box. I need to implement the iAP with that kind of captive portal.
    j-gabs
  • 2.  RE: iAP 105 Captive Portal inquiry
    Posted May 12, 2015 05:12 AM
    The built-in Captive Portal is limited.  You would need to redirect to an external Captive Portal server to get more functionality.  http://community.arubanetworks.com/t5/forums/searchpage/tab/tkb?location=category%3ASupport-Documentation-Downloads&q=instant+external+captive+portal
  • 3.  RE: iAP 105 Captive Portal inquiry
    Posted May 12, 2015 05:25 AM
    Hi cjoseph,
    Thanks for your response. Does that mean that iAP 105 by default does not have the email/name box?
    j-gabs50
  • 4.  RE: iAP 105 Captive Portal inquiry
    Posted May 12, 2015 05:27 AM
     You have to choose "Splash Page type " as "Internal Authenticated" to get all the required options.
     for you ref :
    Please feel free if the issue is not resolved.
  • 5.  RE: iAP 105 Captive Portal inquiry
    Posted May 12, 2015 05:36 AM
    @j-gabs50 wrote:
    Hi cjoseph,
    j-gabs50
    If you change the Captive Portal to Internal- Acknowledged, it will have the email address.  How do you need it to function?
  • 6.  RE: iAP 105 Captive Portal inquiry
    Posted May 12, 2015 05:24 AM
    for you ref :
