IAP 105 client unable to ping gateway
  • 1.  IAP 105 client unable to ping gateway
    Posted Oct 13, 2015 09:22 AM
    I hv configured IAP 105 in standalone mode. configured static ip on IAP interface (from vlan 10)
    I hv configured "Corp" SSID for employee using static 10(vlan id), authentication method wpa2 enterprise with internal database.
    There is no dhcp configured on my switch for vlan 10. i will assign static ip to wireless adapter. User is successfully authenticated.
    I am able to ping gatewayip from AP cli but wi-fi client is not able to ping gatewayip.
    Please suggest troubleshooting steps.
    Thanks in advance..
  • 2.  RE: IAP 105 client unable to ping gateway
    Posted Oct 13, 2015 09:36 AM
    Is vlan 10 trunked to the physical interface of your iap?
  • 3.  RE: IAP 105 client unable to ping gateway
    Posted Oct 13, 2015 12:04 PM
    i am using 10.0.10.X/24 ip range for client and 10.0.10.1 IP for IAP access. Shall i need to configure IAP interface as trunk?
    As i check, i am able to ping gatewayip 10.0.10.10 from IAP but i am not able to ping IAP ip from switch...
    Thanks..
  • 4.  RE: IAP 105 client unable to ping gateway
    Posted Oct 14, 2015 09:56 AM
    Hi Cjoseph,
    After make switch port mode trunk i am able to ping my gatewayip.
    But i lost IAP management access from lan as well associated wlan user.
    do i need to configure management ip address? or do i need to configure uplink management vlan =10
  • 5.  RE: IAP 105 client unable to ping gateway
    Posted Oct 16, 2015 06:39 AM
    Issue has been fixed. Following are the steps.
    Convert port in to access
    VLAN -> Default
    Thanks.
