last person joined: 4 hours ago
IAP 105 Cluster Joining Issue
  • 1.  IAP 105 Cluster Joining Issue
    Posted Dec 02, 2013 07:01 AM
    We had cluster of 10 IAPs 105 but after rebooting 04 of IAP are down and they are not able to joing cluster the other 6 IAP's are working perfectly fine. i have made the factory default to the problematic AP's but no success. When I plug those AP's they get IP address from the DHCP server their power and ethernet LED flash green but their a/n and b/n LED become RED and and do not join cluster and broadcast SSID, Please advice
  • 2.  RE: IAP 105 Cluster Joining Issue
    Posted Dec 02, 2013 07:16 AM
    Make sure those are in the same country code
    Also check that auto join is on
    Can you console into one of the IAPs ?
    Run the log ap-debug from the virtual controller it might show why it can't join ?
    Are those in the same segment ?
  • 3.  RE: IAP 105 Cluster Joining Issue
    Posted Dec 02, 2013 07:27 AM
    Thanks for your response, Please see below reply of your queries.
    YES country code is PK
    Auto Join is Enable
    Not right now because i m not in site
    Dosn't found anything special. Please do let me know what should i look for
    Yes
  • 4.  RE: IAP 105 Cluster Joining Issue
    Posted Dec 02, 2013 08:30 AM
    Did you upgraded recently ? what IAP OS are you running ?
    Can you ping those IAPs ?
    If you don't see any errors when running the AP-Debug , then run the AP Log System
  • 5.  RE: IAP 105 Cluster Joining Issue
    Posted Dec 04, 2013 02:46 AM
    No we didn't upgrade before the problem.
    Yes we are able to ping Ap from net network device
    Now to avoid down time I have reset all the AP's to factory default and configure them again and now everything working fine. It seems there was some problem with VC because i tried my own demo IAP but it also didn't join the VC cluster.
