IAP 105 continual reboot
  • 1.  IAP 105 continual reboot
    Posted Feb 10, 2015 04:03 AM
    I have an AP 105 which is a continual reboot, how to stop it.
    thank you for your help
  • 2.  RE: IAP 105 continual reboot
    Posted Feb 10, 2015 04:41 AM
    Can you console in and post the output?
  • 3.  RE: IAP 105 continual reboot
    Posted Feb 10, 2015 05:02 AM
    Hello Tim capalli
    this is what I have in console, thank you to grant an interest in my publication
    Restarting system.
    APBoot 1.4.0.3 (build 37726)
    Built: 2013-03-21 at 20:13:41
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (6161096 bytes)
    Loading .data @ 0x813e02d0 (32 bytes)
    Clearing .bss @ 0x813e02f0 (16 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing..........................................................
    ú
    Alcatel-Lucent
    AOS-W Version 6.2.1.0-3.3.0.3 (build 39227 / label #39227)
    Built by p4build@cartman on 2013-07-30 at 05:30:46 PDT (gcc version 4.3.3)
    CPU Rev: aa
    71x CPU
    Flash variant: default
    Cache parity protection disabled
    Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
    Memory: 120704k/131072k available (1687k kernel code, 10268k reserved, 625k data, 5352k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=26227712
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> .................................................................................................................................................................................................................................................................................................................................................................................................................
    AR7100 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7100-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    AD7416 driver probing for devices on AR7100 I2C
    .<6>lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: alcatel-lucent.com
    No panic info available
    Testing TPM... Passed
    ag7100_mod: module license 'unspecified' taints kernel.
    AG7100: Length per segment 512
    AG7100: Max segments per packet 4
    AG7100: Max tx descriptor count    400
    AG7100: Max rx descriptor count    252
    AG7100: fifo cfg 3 018001ff
    AG7100CHH: Mac address for unit 0
    AG7100CHH: 9c:1c:12:c9:0c:4d
    ATHRF1: Port 0, Neg Success
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
    ag7100_ring_alloc Allocated 4800 at 0x80354000
    ag7100_ring_alloc Allocated 3024 at 0x8038c000
    AG7100: cfg1 0xf cfg2 0x7014
    ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
    AG7100: unit 0: phy not up carrier 1
    Writing 4
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
    AG7100: pll reg 0x18050010: 0x110000  AG7100: cfg_1: 0x1ff0000
    AG7100: cfg_2: 0x3ff
    AG7100: cfg_3: 0x18001ff
    AG7100: cfg_4: 0xffff
    AG7100: cfg_5: 0xfffef
    AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    wifi uplink not present...
    Ethernet uplink active. Becoming Mesh Portal
    AP xml model 39, num_radios 2 (jiffies 14180)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 8
    radio 1: band 0 ant 0 max_ssid 8
    election init: rand=b HZ=500
    setting bond0 as bridge child
    setting gre0 as split child
    notify asap_mod 3g no present...
    Starting watchdog process...
    Adding bridge entry for magic vlan GW, ifindex 8195, 9c:1c:12:c9:0c:52
    (00:00:28) !!! Init ---> Slave
    Getting an IP address...
    Dec 31 16:00:28 udhcpc[797]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:28 udhcpc[797]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:28 udhcpc[797]: Sending discover...
    Dec 31 16:00:30 udhcpc[797]: send_discover: pkt num 1, secs 2
    Dec 31 16:00:30 udhcpc[797]: Sending discover...
    Dec 31 16:00:32 udhcpc[797]: send_discover: pkt num 2, secs 4
    Dec 31 16:00:32 udhcpc[797]: Sending discover...
    Dec 31 16:00:34 udhcpc[797]: No lease, forking to background.
    Dec 31 16:00:54 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:54 udhcpc[893]: Sending discover...
    Dec 31 16:00:56 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:00:56 udhcpc[893]: Sending discover...
    Dec 31 16:00:58 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:00:58 udhcpc[893]: Sending discover...
    Launching IAP CLI...
    Dec 31 16:01:20 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:01:20 udhcpc[893]: Sending discover...
    Dec 31 16:01:22 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:01:22 udhcpc[893]: Sending discover...
    Dec 31 16:01:24 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:01:24 udhcpc[893]: Sending discover...
    Dec 31 16:01:47 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:01:47 udhcpc[893]: Sending discover...
    Dec 31 16:01:48 udhcpc[893]: send_discover: pkt num 1, secs 1
    Dec 31 16:01:48 udhcpc[893]: Sending discover...
    Dec 31 16:01:50 udhcpc[893]: send_discover: pkt num 2, secs 3
    Dec 31 16:01:50 udhcpc[893]: Sending discover...
    Picked up default IP a9fe519e, rand 519e
    Default IP is ready
    Dec 31 16:02:12 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:02:12 udhcpc[893]: Sending discover...
    Dec 31 16:02:14 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:02:14 udhcpc[893]: Sending discover...
    Dec 31 16:02:16 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:02:16 udhcpc[893]: Sending discover...
    Dec 31 16:02:38 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:02:38 udhcpc[893]: Sending discover...
    Dec 31 16:02:40 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:02:40 udhcpc[893]: Sending discover...
    Dec 31 16:02:42 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:02:42 udhcpc[893]: Sending discover...
    Dec 31 16:03:04 udhcpc[893]: Sending discover...
    Dec 31 16:03:06 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:03:06 udhcpc[893]: Sending discover...
    Dec 31 16:03:08 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:03:08 udhcpc[893]: Sending discover...
    Dec 31 16:03:30 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:03:30 udhcpc[893]: Sending discover...
    Dec 31 16:03:32 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:03:32 udhcpc[893]: Sending discover...
    Dec 31 16:03:34 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:03:34 udhcpc[893]: Sending discover...
    Dec 31 16:03:56 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:03:56 udhcpc[893]: Sending discover...
    Dec 31 16:03:58 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:03:58 udhcpc[893]: Sending discover...
    Dec 31 16:04:00 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:04:00 udhcpc[893]: Sending discover...
    Dec 31 16:04:22 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:04:22 udhcpc[893]: Sending discover...
    Dec 31 16:04:24 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:04:24 udhcpc[893]: Sending discover...
    Dec 31 16:04:26 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:04:26 udhcpc[893]: Sending discover...
    Dec 31 16:04:48 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:04:48 udhcpc[893]: Sending discover...
    Dec 31 16:04:50 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:04:50 udhcpc[893]: Sending discover...
    Dec 31 16:04:52 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:04:52 udhcpc[893]: Sending discover...
    Dec 31 16:05:14 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:05:14 udhcpc[893]: Sending discover...
    Dec 31 16:05:17 udhcpc[893]: send_discover: pkt num 1, secs 3
    Dec 31 16:05:17 udhcpc[893]: Sending discover...
    Dec 31 16:05:18 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:05:18 udhcpc[893]: Sending discover...
    Dec 31 16:05:40 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:05:40 udhcpc[893]: Sending discover...
    Dec 31 16:05:42 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:05:42 udhcpc[893]: Sending discover...
    Dec 31 16:05:44 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:05:44 udhcpc[893]: Sending discover...
    Dec 31 16:06:06 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:06:06 udhcpc[893]: Sending discover...
    Dec 31 16:06:08 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:06:08 udhcpc[893]: Sending discover...
    Dec 31 16:06:10 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:06:10 udhcpc[893]: Sending discover...
    Dec 31 16:06:32 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:06:32 udhcpc[893]: Sending discover...
    Dec 31 16:06:34 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:06:34 udhcpc[893]: Sending discover...
    Dec 31 16:06:36 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:06:36 udhcpc[893]: Sending discover...
    Dec 31 16:06:58 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:06:58 udhcpc[893]: Sending discover...
    Dec 31 16:07:00 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:07:00 udhcpc[893]: Sending discover...
    Dec 31 16:07:02 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:07:02 udhcpc[893]: Sending discover...
    Dec 31 16:07:24 udhcpc[893]: send_discover: pkt num 0, secs 0
    Dec 31 16:07:24 udhcpc[893]: Sending discover...
    Dec 31 16:07:26 udhcpc[893]: send_discover: pkt num 1, secs 2
    Dec 31 16:07:26 udhcpc[893]: Sending discover...
    Dec 31 16:07:28 udhcpc[893]: send_discover: pkt num 2, secs 4
    Dec 31 16:07:28 udhcpc[893]: Sending discover...
  • 4.  RE: IAP 105 continual reboot
    Posted Feb 10, 2015 05:13 AM
    The AP is not getting an IP address.
  • 5.  RE: IAP 105 continual reboot
    Posted Feb 10, 2015 05:22 AM
    Thank's for your help Mr. Tim Capalli
  • 6.  RE: IAP 105 continual reboot
    Posted Dec 16, 2016 02:33 PM
    But, how do you fix that? I can not enter to the web interface, it does not propagate any ssid and the console, it makes that al the time.
  • 7.  RE: IAP 105 continual reboot
    Posted Dec 16, 2016 06:39 PM
    You can fix it by supplying DHCP to the Instant AP.
