IAP-105 & Controller
  • 1.  IAP-105 & Controller
    Posted Jul 27, 2013 04:57 AM
    i will buy Controller 3200 , and 25 AP-105
    Thinking to buy them as IAP-105  not AP-105  , sothat i ncan convert what i need bto AP-105 ( softwrae re-image )  & have the ability to use Instant APs with out controller if needed
    is this true ?  do i have any limitations is this idea  ?
    #3200
  • 2.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 04:59 AM
    & if So , why doesn't all use thsi method , instead of byuing AP-105 ?
    IAP-105 will give both options   ( controller based & conytroller less )  with same cost ?
  • 3.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 06:04 AM
    Some client really does it. :smileywink: and choose this option - it's giving them some flexibility in different deployments methods.
    BUT..
    • It will do the installation part a bit longer - because u should convert all your iAP to AP...One by one.
    • InstantAP have reset button - and those units can be rested to factory defaults = from CAP back to iAP..
    That's it. All the rest is the same.  :smileyvery-happy:
    Just a small tip: In order to convert instant to controller environment - just make sure your controller AOS version is supporting it.
    (This should only work with ArubaOS 6.1 and above)
    Me.
  • 4.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 08:36 AM
    Thanks alot , based on that i will but IAP not AP   :)
  • 5.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 09:04 AM
    Actually. You don't need to convert one by one. Just form them into a cluster and then you can convert them all with a few clicks.
  • 6.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 09:08 AM
    yep - it's also a working method.
  • 7.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 09:13 AM
    So you can convert a bunch of IAPs into Campus APs in one shot ?
  • 8.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 09:19 AM
    Yes. That is correct.
    Sent from my iPhone
  • 9.  RE: IAP-105 & Controller
    Posted Jul 27, 2013 09:21 AM
    Good to know
