iap 105 does not boot from scratch
  • 1.  iap 105 does not boot from scratch
    Posted Aug 25, 2013 02:15 AM
    I am a newbie to Aruba. I inherited two Aruba 105 access points which I tried to start up from scratch. The ap's are straight from the box. I want to use use the ap's without a controller.
    I found the instant.aruba docs to start up the ap's. But both the ap's stop autoconfiguring after some DNS requests.
    Here the startup sequence from one of the ap's:
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU:   AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM:  128 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  0029 00002   01 10000000 00000000 00000000 00000000
           01  00  168c  0029 00002   01 10010000 00000000 00000000 00000000
    Net:   eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 192.168.2.19
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.2.254
    DHCP DNS server: 192.168.2.254
    DHCP DNS domain: lan
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master.lan to 192.168.2.254
    T T T T
    Retry count exceeded; starting again
    Here it stops and nothing happens anymore.
    I tried to connect without success using SSH and ftp.
    Can someone give me a clue how to go on from here?
    Regards, Fons
  • 2.  RE: iap 105 does not boot from scratch
    Posted Aug 25, 2013 04:17 AM
    There are two different AP105 units:
    AP-105 (Only managed by controller)
    and
    IAP-105 (InstantAP units,can be used as virtual controller,and also converted and connected to controller)
    to figure out which ap you bought,just turn over the ap - and look for a white sticker.
    • If it's written AP-105 .So it's can't be an instant unit. <if this is the case - u must use a controller.
    • If it's written IAP-105-so it's an instantAP unit and can act as a virtual controller. <if so u got a reset button in the back of the ap unit,reset it to factory default>
    That's it .
    Have a great week.
    Me
    BTW:
    fromt the boot it's look like a AP-105 (not instant) unit.
  • 3.  RE: iap 105 does not boot from scratch
    Posted Jun 08, 2019 01:37 PM
    I got a 134 with the exact same issue mine is a AP not a IAP guess i need a VC. thanks for your help everyone.
  • 4.  RE: iap 105 does not boot from scratch
    Posted Jun 11, 2019 08:26 PM
    You will need a physical controller for that to work. If it was an IAP, then it could operate as a virtual controller (VC), or join a cluster of one or more other IAPs that already has an IAP functioning as a VC.
    I hope this helps,
