last person joined: 4 hours ago
IAP 105 external web authentication
  • 1.  IAP 105 external web authentication
    Posted Sep 16, 2012 03:32 AM
    In the IAP 105 there is an option for the IAP to direct the user for the web authentication to a remote web server, and to set an authentication text.
    Is there any template to how the web page should send the authentication text?
    Best regards,
    Omer Shtivi
  • 2.  RE: IAP 105 external web authentication
    Posted Sep 16, 2012 12:15 PM
    You can do this for the Guest network. Create a new network with the type set to Guest > use Virtual Controller assigned for the IP Address and set a static vlan if needed, then under security set the Splash Page for External - RADIUS Server.
    See the screen capture below. Also see the Authentication chapter in the IAP User's Guide under the heading "External Captive Portal".
  • 3.  RE: IAP 105 external web authentication
    Posted Sep 17, 2012 05:08 AM
    Thank you,
    But I still doesn't get how the radius server and the web page communicate
  • 4.  RE: IAP 105 external web authentication
    Posted Jun 26, 2013 09:39 AM
    Hi, did you find a template to do that?
    Thank you
