IAP-105 - FIrmware Update No Response from Server
  • 1.  IAP-105 - FIrmware Update No Response from Server
    Posted Jun 08, 2016 04:48 PM
    I am trying to update my aruba 105 but I keep getting a message saying "no response from server". I checked and the certificate doesn't expire till 2017. Can someone please send me the latest firmware?
    Thank you
  • 2.  RE: IAP-105 - FIrmware Update No Response from Server
  • 3.  RE: IAP-105 - FIrmware Update No Response from Server
    Posted Jul 10, 2017 09:16 AM
    Hi Colin
    I have the same problem, I have clicked on the link and downloaded the latest release ArubaInstant_Orion_6.4.2.6-4.1.3.2_56106 when I upload it to the AP is gives the folling error
    Invalid image File
  • 4.  RE: IAP-105 - FIrmware Update No Response from Server
  • 5.  RE: IAP-105 - FIrmware Update No Response from Server
    Posted Jul 10, 2017 10:01 AM
    Hi Colin, thanks for the quick reply,
    I tried it but got the same responce
    Invalid Image File
  • 6.  RE: IAP-105 - FIrmware Update No Response from Server
    Posted Jul 10, 2017 11:43 AM
    Does your Image file have parentheses in the filename?  If yes, please remove it.  Also you should download the Aruba.sha.256 file and do an md5 sum against the image to see if your download is corrupted or not.
    https://support.microsoft.com/en-us/help/889768/how-to-compute-the-md5-or-sha-1-cryptographic-hash-values-for-a-file
