IAP 105 firware update - Palo Alto Integration?
  • 1.  IAP 105 firware update - Palo Alto Integration?
    Posted Mar 31, 2014 12:01 PM
    what exactly is this service option used for?  We do have PA FW's in our environment.
  • 2.  RE: IAP 105 firware update - Palo Alto Integration?
    Posted Mar 31, 2014 12:08 PM
    Please refer to the Instant 4.0 Users Guide under Integrating an IAP with Palo Alto Networks Firewall for details.  In a nut-shell it allows information to be shared between the Palo Alto firewall and IAP regarding Users, roles, and levels of access.
    If you do not have PAN there is no need to enable it.
