IAP-105 Guest User DHCP Pool
  • 1.  IAP-105 Guest User DHCP Pool
    Posted Apr 19, 2013 01:37 PM
    Went from 6.1.3.1-3.0.0.2_34479 --> 6.1.3.4-3.1.0.0_35320 and the virtually assigned IP pool for guest users changed from 172.16.11.x to 192.168.10.x.. I need to upgrade to this version because it supports ETH0 bridging... however, I have a routable network internally on the 192.168.10.x network and all other controllers and virtual controllers on the network are already on the 172.16.11.x network.  Anyway to change the default IP pool that the virtual controller assigns?
  • 2.  RE: IAP-105 Guest User DHCP Pool
    Posted Apr 19, 2013 03:23 PM
    Good evening,
    You might wanna try to re configure your DHCP settings in your VC:
  • 3.  RE: IAP-105 Guest User DHCP Pool
    Posted Apr 19, 2013 03:39 PM
    i dont have that option.. I upgraded to the latest code and now I am getting this error.. on IE9 32bit
  • 4.  RE: IAP-105 Guest User DHCP Pool
    Posted Apr 19, 2013 03:48 PM
    Some people have reported this issue with that version of IE.  Try running IE in "Compatibility View / Mode"....that should take care of the IE error.
  • 5.  RE: IAP-105 Guest User DHCP Pool
    Posted Apr 19, 2013 04:41 PM
    IP pool is now working as expected.. however, cant sign into VC with DNS name since the upgrade.  Only by IP address.  I tried compatability view/mode, no good.
  • 6.  RE: IAP-105 Guest User DHCP Pool
    Posted Apr 20, 2013 05:14 AM
    different browser?
