IAP-105 PASSWORD RESET
  • 1.  IAP-105 PASSWORD RESET
    Posted Nov 28, 2017 11:22 AM
    Hi, I've a couple of IAP -105 and the problem is that the administration password got lost.  I've tried to connect to  master IAP using a console cable, and use admin "admin" / password "forgetme!" or admin "password" but not working.
    thanks for any help!
  • 2.  RE: IAP-105 PASSWORD RESET
    Posted Nov 28, 2017 07:19 PM
    Hi-
    Due to security reasons the password reset functionality was removed. You will need to perform a factory reset on your IAP's.
