IAP-105-US upgrade from 5.0.3.0 to 6.2.0.0 - 3.2.0.0_36559 Unable to get to VC
  • 1.  IAP-105-US upgrade from 5.0.3.0 to 6.2.0.0 - 3.2.0.0_36559 Unable to get to VC
    Posted Feb 06, 2013 01:11 PM
    I performed an update from 5.0.30 – 1.1.01_29974 TO 6.2.0.0 – 3.2.0.0_36559 and am experiencing the following problems.
    I am unable to reach the HTTPS interface to the Virtual Controller. I am able however to reach HTTPS:\\<IP OF IAP>:4343 and login. However, when I log in, the dashboard shows completely blank, and the only links that seemingly allow me to click on them is the "Maintenance" and "Support" links. I can SSH into 5 out of 6 of my IAP's. I tried logging into one of the IAP's and performing a reload to try and reboot the IAP and I am now unable to login with my admin password. I have tried the default admin password, but am unable to login.
    I have 6 of the IAP's directly connected to a Dell PowerConnect 5548P (POE) switch. I have two SSID's on the VC. One is for employee traffic, and the other is for customer traffic. The main network is on the employee network on VLAN 1.
    I have tried to unplugging the IAP's at the switch to perform a reboot of the IAP's and still I am experiencing this odd behavior.
    Can someone please suggest a course of action for fixing this issue? I have 6 IAP's and most of them are in not easily reachable locations.
    Main Closet Switch
    console# show run interface gigabitethernet1/0/16-19
    description ARUBA_IAP_105
    spanning-tree disable
    spanning-tree portfast
    no eee lldp enable
    switchport mode general
    switchport general allowed vlan add 2 tagged
    switchport general allowed vlan add 1 untagged
    interface gigabitethernet1/0/17
    interface gigabitethernet1/0/18
    interface gigabitethernet1/0/19
    spanning-tree cost 2000000
    switchport access vlan 2
    Network Closet Switch
    console# show run interface 1/0/20
    % Unrecognized command
    console# show run interface gigabitethernet1/0/20
    description ARUBA_IAP_105_US
    console# show run interface gigabitethernet1/0/33
  • 2.  RE: IAP-105-US upgrade from 5.0.3.0 to 6.2.0.0 - 3.2.0.0_36559 Unable to get to VC
    Posted Feb 06, 2013 05:18 PM
    Do you remenber which one had the role of master?
    If you do try unplugging that one, and then some other AP will take over, and will be the master.  After that try to log in
    But leave the one that was master off while you doing it.
  • 3.  RE: IAP-105-US upgrade from 5.0.3.0 to 6.2.0.0 - 3.2.0.0_36559 Unable to get to VC
    Posted Feb 07, 2013 06:06 PM
    We just experienced a similar problem. I found that we could access the GUI on the virtual controller right after a reload or when there were few clients on the network. I worked with support and there is a patch in development. They had me move back to the previous code level to resolve the issue.
  • 4.  RE: IAP-105-US upgrade from 5.0.3.0 to 6.2.0.0 - 3.2.0.0_36559 Unable to get to VC
    Posted Feb 08, 2013 04:33 PM
    We saw a similar problem in 6.1.3.4-3.1.0.1_35899 and were asked to upgrade.
    I saw 6.2.0.0-3.2.0.1_36986 came out on Tuesday (Well I saw it on Tuesday anyway)
    I'll try that instead of 36559 and let you know what I see.
