IAP-105 VLAN issue
  • 1.  IAP-105 VLAN issue
    Posted Aug 21, 2013 02:52 PM
    Having issues with a guest WiFi network on a second VLAN (150), this started after a firmware update and I cannot figure this out; I'm thinking there is a bug.  We have 5 IAP-105 devices plugged into 2 HP switches.  Both switches are trunked allowing all vlans, APs are plugged into trunked ports as well.  Our router is a juniper SRX, with a guest VLAN #150.
    SRX Gateway: 192.168.10.1  (this is the DHCP server)
    Switch#1 vlan interface: 192.168.10.5
    Switch#2 vlan interface: 192.168.10.6
    Client joins and obtains 192.168.10.120
    Both switches can ping each other, as well as the gateway.  Gateway can ping switches.  The switches can also ping a wireless client joined to the guest network, as well as the guest ping the switches.
    Here is where things get wierd.  The client obtains a DHCP address from the gateway, but can not ping it or make external DNS queries.  The gateway can't ping the client either.  If I hardwire a laptop into the switch on vlan 150 I can ping the gateway as well as the switches and browse the internet.  It's odd.
    Previous version: 6.1.3.0-3.0.0
    Current version: 6.2.1.0-3.3.0.2
    Any ideas would be great!  Thanks in advance.
  • 2.  RE: IAP-105 VLAN issue
    Posted Aug 21, 2013 04:04 PM
    Do you have your guest users in a role that is blocking that type of traffic?
  • 3.  RE: IAP-105 VLAN issue
    Posted Aug 22, 2013 11:48 AM
    Not that I see.  It's another "Employee" network type set to unrestricted.  I have tried resetting to factory defaults to clear the problem, but no luck.  This started after the firmware upgrade which is wierd, I have no way of rolling back to the old version unless I can find the image somewhere.
    Sorry, I am new to the Aruba gear.
  • 4.  RE: IAP-105 VLAN issue
    Posted Aug 22, 2013 02:16 PM
    With a laptop connected wirelessly, I am able to ping the SRX gateway and browse the internet if I manually add a static ARP entry for the juniper on the laptop.
    Once I remove the ARP entry, communication stops.
