IAP-105 WPA2 Problems
  • 1.  IAP-105 WPA2 Problems
    Posted May 15, 2013 01:22 PM
    I recently purchased 3 iAP-105s for a smaller office but im having problems getting a WPA2 network using only the internal database going.
    When i try to connect with one of my computers it complains that the authentication server did not respond.
    I currently do not have any SSL certificate uploaded to the server and figured this was the issue.  So I purchased an SSL certificate for my domain name using an openssl csr and a .pem certificate.
    When i try to upload the certificate to the IAP i get the following error though:
    "Decode RSA key error"
    The certificate was created using RSA 2048.
    Does anyone know how to fix this ?
  • 2.  RE: IAP-105 WPA2 Problems
    Posted May 16, 2013 02:53 AM
    You need to upload the certificate file in PEM or PKCS#12 format with passphrase (PSK). Did you enter (correctly) the passphrase?
    Once you have uploaded the cert you will be able to use PEAP + TTLS (for TLS you also need a CA certificate and certificates issued to the clients).
